what is your initial? ported or manifold? pull the idle mixture screws & blast the holes with a 3 second blast of starting fluid then replace the screws (count # of turns to lightly seated to easily return em to their original position). you might install a gutted PV so it's idling on the power circuit which MIGHT point to a vac leak. post how it goes.
