You may think you don't need data logging but it will make your tuning life much more pleasant if you have it.
Kevin
right there... log it if you can. ive had a couple lc1's over the years. I thought they were OK and work well for the price. I have had wonky sensors, but new ones are in stock at the local parts store.
bro dave says otherwise, depends on how much you want to spend:
I own several Innovates but have always found them to be really fussy and not the best reliablilty.
The best wideband for the price is NGK AFX.
It's control logic was developed by the same guys at ECM, who make lab grade widebands. I have a AFX in my Srt and I tune with a lab quality ECM AFM1000(+$1500), they're dead on to each other. The AFX also uses a more reliable and accurate NTK sensor.
Not a fan of AEM. The cheapest wideband on the market is rarely worth buying. Most AEM show around 1/2-3/4 point lean at WOT when compared to my AFM1000.
