If the carb worked fine before you made the other changes to the engine then I would suspect the other changes. Perhaps the cam was installed one tooth retarded or something like that?
An out of the box Dominator should start and idle okay. The 3 circuit carbs tend to be dead rich off-idle but they should start and run okay.
