I ain't up on BB intricasies but iirc you (1) pull the pipe plug (2) install the rod all the way up thru that (pipe plug) hole till it is seated with some grease on the leading end of it to hold it up there (3) replace the pipe plug (4) install the pump with the arm under the rod
