meep got it figured out , his centerlink was put in backwards before he bought the car and when he restored the car he put it back assuming it was correct , it wasn't , he's got 3/4" clearance ... but that is with the shcumacher 3/16" shims because the mounts he used were thinner than factory original ... which is the case with the India and Korea sourced mounts I believe.
He'll be replacing those after the first burnout ...
