Unlike the stock mounts the poly locks don't settle. Same holds true for the Polygraphites. That gives the impression they are taller. It becomes an issue with the fitment of headers or a stock exhaust system from TTI or Accurate. I have run into figment issues using used rubber mounts. I believe the exhaust vendors use stock rubber mounts when the mocked up their systems.
“So if it’s on the internet it must be true”
Abe Lincoln
