Quicktree u did answer my question. What size of port do you have on your indy small block heads
Some good stories keep them coming.
it's been so long I don't even remember. I have 2 sets of 360-1s. one was ported by Dwayne porter and were flowing around 317 on the intake side @ 700 lift. not a max port job but had great low lift numbers. ran strong on my stock stroke 360. the other set were max ported from some guy up in Minnesota. they flowed like 335 @ 700, this was on my stroker motor in the arrow. both very mild combo's the stroker made about 100hp more.
The reason I was asking is I found a set of intake gaskets but they r for the 230 CNC heads. Oval ports.
I was going to ship them to you free so you could buy your 5 dollar AN fitting. Lol
