68 barracuda, 3200 to 3250 depending on the day on new england dragway scales, solid roller, .646 lift, 11 to 1, MW port SR heads by Dwayne. 470ci
It will typically run 9.90 to 95 at new england until the temp gets over 85 then will be up to 10.0 to 10.05 w/1050 4150 version. This is with no tuning for weather. Planning on raising the compression ratio, not too much left in the heads, will be a cam change. Going for 9.80s when hot.
I'm planning on testing the modman and edelbrocks with no other changes to see the effect from just those.
Did you ever try a before and after with the modman?
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge
New New Best: 10.56 @129
68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up
https://www.youtube.com/watch?v=T4jDLKwd9Gs
