So I ended up cutting a cool and a half from my front coils on my drag pick up. Also put the rear above the springs. I'm on a tight budget with the current oil prices causing low work hours. My question is what shocks should I run on the front and rear. I'd prefer to run something I can just get at Napa for now. Nothing too fancy. The front ones have the two bolts going up into the lower control arm and the tears are gonna need to be quite a bit shorter also. Anyone with part numbers?
