It should hold pressure a long time. I tested a big block that was losing coolant. Tested cold, it held pressure for 12 hours overnight. 16 psi and didn't bleed off a single pound. When hot though, it leaked coolant into the chamber and sent it out the pipe as steam.
If you can't maintain ANY pressure, definitely need to dig deeper
**Photobucket sucks**
