The problem I have is that if I use a 1-3/4 hose adapter on the bottom of the water pump it directs the hose right into the path of the alternator belt.I cant switch it to the drivers side on the car I am working on (power steering pump).The threads on the bottom of the pump angle the hose adapter towards the front.Has anyone else run into this?Is the best fix to use AN hose adapter and a 45 or 90 deg hose end?
410 pump gas solis flat tappet cam 10.95 so far
