That cam really needs 4.56-4.88, and 4800-5000 converter, but I understand your choices. The only thing I could think is to try backing off on the total timing a couple degrees( 1 deg at a time). The LD-340 and 3.91's will help quite a bit.
Yeah, it's got a smallblock.
