You're probably going to turn too many RPM for a typical aggressive hydraulic to keep control of the valve train. Pitch the hydraulic cam and put a properly sized solid in there.
The old Mopar .590 cam always worked good for a car like that.But you could get a more modern design solid with similar specs.
