I can tell you I moved mine a few times and it did absolutely nothing.
What did you move Tony.. IC length or height.. once
you find the right place there is only 4-6 changes that
work for your car... yeah the 4 link has a pile of
adjustment points but that helps you find the RIGHT
points to play in... once you find the right place
you only get a few minor moves
both, made no difference on the way the car reacted, just not enough power.
