Would there be any benefit on an autocross car? IE: NO deflection...
If you do not have at least some rubber material for absorbing vibration between the road and the body you will have a lot of vibration. That vibration will probably lead to premature loosening of bolts and higher chassis stresses that may lead to premature component failure.
If it were me I would keep to poly bushings for road racing but in a drag race situation the stresses are greatly decreased because of the length of time the chassis is "worked" is seconds per race not hours.
My
