it doesnt work very good....
CAR: Plymouth RoadRunner 2 Door Pillar Coupe ENGINE: 426cid Hemi 2x4-bbl HP V8 TRANSMISSION: 3-Speed Automatic TIRES: F70x15 Red Side Wall, nylon belted BUILD DATE: September 12. AXLE: Unknown Axle Code INTERIOR: Gold Interior. PAINT: OTHER:
MOLDINGS: 15: Unknown Option 20: Unknown Option 44: Unknown Option 58: Unknown Option 720: Unknown Option 84: Unknown Option
ABC OPTIONS: Z1: Unknown Option
abc OPTIONS: q6: Unknown Option
Well it worked on my RT but I could get it to work on your's either.
I'll fill in what I think I knew,
The 48 under axle code is 4=3.23 8=sure grip
The paint is I believe bronze metalic/root beer/ FK5 like - MM1
The upper door frames are gold - the Y under the U
The 164855 is the sequence number and should be on the core support and the driver trunk rail, not sure about the cowl on 68s
m6 shows to be driver's outside mirro A1 shows to be a 26 inch radiator
I think it's an alignment thing, I did better than you but I will work on it some more.
CAR: Plymouth RoadRunner 2 Door Pillar Coupe ENGINE: 426cid Hemi 2x4-bbl HP V8 TRANSMISSION: 3-Speed Automatic TIRES: F70x15 Red Side Wall, nylon belted BUILD DATE: September 12. AXLE: 3.23 Rear Axle Ratio, Sure Grip INTERIOR: Deluxe Trim Grade, Vinyl Split Bench Seats. PAINT: Monotone Bronze Metallic Paint. OTHER: Medium Tan Metallic Upper Door Frame Color.
MOLDINGS: 35: Unknown Option 40: Unknown Option
ABC OPTIONS: A1: 26in Radiator R1: AM Radio
abc OPTIONS: m6: Driver's Outside Remote Operated Mirror
Careful, your character's showing!
