Just a thought, another way to raise compression would be to angle mill a set of heads. Careful pre-planning is the word of the day, though the results would be worth while. Don't go crazy on cam lift and no knotching of pistons required.
Other wise re-piston with some KB 167's and the thinest head gaskets you can find.
Good luck!
Jim Burch
