if the engine was recently rebuilt, why not run it as is? sure, it will be less than ideal, but changing pistons and heads will be almost like starting over. i think i would put the engine in and enjoy it while saving to build the engine you really want. keep in mind, if starting from scratch, a 360 can be built as cheaply as a 318.
