Quote: thought I had this figured out with the wiseco k0011b4 dome. wont work, made for standard head. gonna be custom deal with wiseco. mahle has nothing and a custom piston thru them is about $1600/set. diamond has nothing either. looking for something to make about 13.5:1 with a 4" stroke.
Diamond and most others will build you whatever you want. You are only a chamber mold away from getting EXACTLY what you want
