Yes - the ports are raised. Looks like the manifold is about 3/4" up off the valley rail - with a 1/2" spacer under the carb maybe that is enough to cause the height issue. I will probably remove the spacer and just keep the smaller billet air cleaners that can protrude slightly through the cutouts in the hood.
