i see a couple things have gone unanswered. first i do not have a wideband, the bore is 4.060 stroke is 4.00. i have one last question, any chasis change suggestions or upgrades. just have 6 cyl. bars and 90-10 ce shocks. also what needle and seat should i use i have the ones in question? thanks for your time.
I like to put .120 or .130 needle/seats in my carbs..
as said check timing squirter shot (both start and
finish)... I'm not a fan of the shocks... I like a
better adjustable one... get the best you can.. the
6 cyl bars are fine.. make sure you have good front
end travel, do a flow test on the fuel system... also
whats your cranking pressure
