prretty much out of the box 950 hp carb, avgmph prob 123. this is after the chang e from 4200 to 4800 conv. 124. to125 before same et. went up to the 1-7/8 headers along the line. also i do have a 1 inch spacer under the carb, been there since the start. dynoed flatteron the tq.
Whats your fuel supply system... your MPH is low so
I'm wondering if its a fuel issue.... I should say its
low for the HP that you stated but is in line with
your ET now
