It may but that is a custom disc manufactured by RC&B. There are even better friction materials than what is in the picture. The 10.95 p-p in the pic is a 2800lb clutch that currently resides behind a 400 rear wheel hp stroker and the pedal effort is easy.
For the custom p-p you get to decide how much pressure you want ie 2200lbs, 2600 lbs etc. Each p-p is carefully and individually manufactured, and the person who does the work has over 25 yrs experience. Being around since 1924 allows RC&B to build clutches on fixturing that is precise and exact, unlike the mass produced clutches of today.
Too many variables for one size fits all.
If you have an off the shelf car then use an off the shelf one size fits all clutch.
