....I run a 10.95 McLeod diaphragm with the overcenter spring in place and an adjustable positive stop on the clutch pedal in the Cuda. This gives a light modern feel and the stop prevents overcentering the clutch diaphragm.....
Do you have an installed picture of your Positive Stop?
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
