Quote: I call the shop and the guy says to go ahead and start it up that the plug will stop leaking once it gets up to temp. Is this correct. [quote/] (1) not correct. I'd go ahead and pull it & drive in a new one/with sealant. & since they butchered a kindergarten level job like the freeze plugs, before firing I'd pump the system up to 15 or 20 lbs & see if it holds. SB's have (2) in the back bell area
Ya, that's what I was thinking I should do. Thanks bud. I sure learned a lesson about just going with the cheapest place available. I would have been better off paying a couple hundred more to have a more reputable place do the job.
