Rally dash speedo in my challenger looks pretty good, but when put into operation this past summer, it quickly became very noisy, needle started jumping, and promptly broke off! I need to fix it. Should I remove the speedo and have it restored or just buy one of the repops I see available?
Jess
There is a plastic gear in the speedometer that gets a slight crack in it and slips and usually causes the needle to go to 160 hit the stop and break. Once you send it to have the gear replaced it should work fine.
