On my '71 Cuda, the Low beams will not come on by themselves... ala carte. They DO come on when I also turn on the High beams...all 4 headlights do. At 1st I thought this would be a faulty floor switch, but I removed the switch and test-jumpered from the "Hot" wire that feeds the switch, and then into the Violet wire leading out, which the wiring diagram shows as going directly to the Low Beam side of the headlights.
Nothing!
What am I missing here? They've never worked since I bought this car a couple of years ago... I don't drive at night, but I WOULD like to get this fixed!
Thanks for your help in advance
![](/ubbthreads/images/graemlins/wink.gif)
