I found out that there is no fuel reaching the carb. I disconnected the fuel line at the carb and and cranked it over--no fuel discharge. I then disconnected the line at the pump outlet and no fuel discharge there either.I installed a used pump that I have and still no luck. When I get the Fury home I'll try the container under the hood test. If the sock filter in the tank is plugged can they be purchased or could I eliminate it and install an inline filter just outside the tank? Thanks for the info here.
John
