I'm wondering if the sock in the tank is partly plugged & intermittently stopping the flow & that was the problem all along. You might hook a can of gas in the eng compartment to the pump inlet which would tell you if it's in the pump/carb or rearward & I would check the neoprene line at the tank & maybe popping the carb top & see if anything looks amiss.
