North Alabama
None of my many "car" projects are even NEAR the front burner right now, much less ON it.........LOL!!!
Lets see...........
Finish new shop Finish new reloading room and sight in about 10 rifles, as well as work up some loads.....I do long range shooting as a hobby Finish new motor for Jet Boat Finish resto on 81 XR500 Finish EFI conversion on CJ5 Finish changing out rear swingarm and fenders on Harley...........and THEN, I need to work on Challenger, Lil Red truck, GTX, 63 Dodge, etc, etc, etc..........LOL!!!!
Monte
What motor are you building for the Jet Boat?
Alum headed 515 BBC, with a 6/71 and hidden EFI in the hat.
Here is boat with previous motor
Monte
Dang Monte that is badass! Hey I was talking to a boat mechanic and he was telling me not to turn those jets past 5500 rpm or they could blow, and I was thinking yeah, anything will come apart if you spin it high enough but 5500 seems a little tame for performance. What modifications do I need to perform for the extra load?
Its all about "loading" the pump properly. Be that with a certain loader, a different cut impeller, nozzle bushing, whatever. Sounds like you should talk to someone who KNOWS jetboats.....not just a boat mechanic. It's true that you build for torque, NOT rpm as you can't spin a jet pump to the moon, but pretty much ANY stock jet drive will be fine to 5500. And it's NOT that it will come apart after that......it just cavitates so much water, the extra rpm gains you nothing.
Monte
