Quote: Take out the back seat and crawl into the trunk. You can then use a regular screwdriver to turn the latch from inside. I wonder if the metal tab that runs from the lock tumbler to the latch broke.
No can do. I have a welded in rear firewall that has fresh carpeting glued to it. Thanks for the suggestion though.
Your either going to have to drill a hole through the rear firewall large enough to pass a long tool through or drill/punch out the trunk lock.
