I guess ALL the manufacturers are wrong. Why have a proportioning valve at all ? So it evens out the pressure from the front to the rear. Hydraulics, Closest to the first point of contact.
Quote: Yes If not it will always hit fronts first. Since they are the closest to the M/C
What? Someone has no idea about hydraulics here.
No, in an all drum setup you do not need a proportioning valve.
