Have the bowls cleaned up on the heads, valve job
and put the 340 cam in it with the right springs..
not the stock 340 springs
Any special valve job? Is it a stock mopAr cam?
For what your doing a 3 angle will work... a 5 angle
will get a bit better power... on the cam.. I remember
.444 lift... if you want to go after market you
can go a bit more but keep the duration down so it makes
some cyl pressure
