If you don't like the squeaks, creaks, and rattles, then install subframe connectors. They will do more to eliminate the noises then sound deadener will do to reduce it.
While I agree 100% on the frame connectors, I dis agree on the application here. They will do nothing as a heat barrier, which was an issue in my car before I restored it. The matting not only quieted the interior, but made it a bit more comfortable too.
`68 Barracuda 340-S
