Hey guy's what kind of sealer do you use on a freeze plug instalation,,,,,,,I have always used the #1 brown sealer on mine,,,,,, but I have a '68 hp block and have had issues with the plugs for the last 3 seasons,,,,,,just had it out to freshen it up,,,,,,and went back with the brass again,,,,,,,fired it up yesterday and already have 2 leaking,,,,,,,I have ran it since I put it in the car with the rubber expansion plugs cause I had problems with it from the get go,,, and was wondering if it is a problem with the block other than my installation technique,,,guess it's rubber biscuit time again,,,,,,really po'ed about this block,,,,,but It's still usable so it will get used up.........
Thanks Dave
This is what I use... put some Permetex around it and put it in and tighten it up
