You know those are not really freeze plugs but are there to clean the sand out after the block is cast. I use brass plugs and JB Weld. Never had one leak or blow out. Brass does not corrode/rust like steel plugs do. Re placing them could be a job but I ain't never replaced one so I don't know.
