Should i have all drums turned provided they arent out of tolerence?Is it a necessity to put on new shoes again if i turn the drums?
Depends on how much you have driven it with the shoes wearing to the uneven surface of your worn drum.
Seriously you should upgrade at least the fronts to discs , the drum brakes never worked that great even when they were new .
