Oh I ain't spending $700 or a large fraction thereof for the solution. Regardless of if it's in stock or not.
I have a much cheaper solution, it's been posted a few times but one more time
http://autoperformanceengineering.com/html/pickups.html
very cool!!! curious, do you replace this with the stock sock that's in you tank for your pump?
You'd remove the stock sock off the stock pickup tube and plumb these pickups to it. I used an external pump for my changeover, cause that's what Holley put in the kit.
They say there are no such thing as a stupid question. They say there is always the exception that proves the rule. Don't be the exception.
