Take a hair dryer or heat gun and warm up the pin boss area and push them out, you may have some corrosion If so scotch brite and WD 40 will help clean them up, make sure to use a rust preventive on them when you reassemble them, not WD40 WD40 = Water Displacement formula #40, it evaporates and does not prevent rust is what I think
