STOP NOW. The stock ball joint steering arms will not work when reversed. It has to do with Ackermann. Ackermann causes the inside tire to turn a tighter radius than the outer tire. When the arms are reversed inner tire now toes in (toward the outer tire). Serious scrubbing will result in poor handling while turning and extreme tire wear. The outer tie rod location must also form a parallelogram when viewed from the front. The 4 corners being the lower control arm pivot, inner tie rod, outer tie rod, and lower ball joint C/L.
Read about ackermann here.
http://en.wikipedia.org/wiki/Ackermann_steering_geometry.Any questions,please ask.
Doug
