Crane 99476-1
Did all 16 springs in the car with this - worked flawlessly...but make sure you keep the screw down lubed....
http://www.summitracing.com/int/parts/crn-99476-1.
This is what I was thinking of. I built the shaft piece like in the picture and then a pull-down lever the first trial. That is when I found out that I only had 2 arms/hands and my first design required at least 3!! This one gives me some more ideas to try. Thanks.
If you like drag racing, support your local track.
