Is it possible to back the trailer up to the post lift and not use any ramps?
Your brother moving his shop or closing up?
my trailer is 8ft wide and so is the garage door opening. i plan to back it to the post if i can and pull it on to the trailer.i have an open center trailewr so i need the ramps to close the gap between the outer ramps that the tires ride on on the frame.if i can stabilize the dyno with the ramps by putting them under it and then pull it on the trailer it may be safer to move that way.
