my dakota is 3360# with me and full cell of gas, motor is 340 .040 over 4" cast crank, 9.8 compression,diamond dish pistons,scat i beam rods,cast iron x-heads fully ported ,custom crane cams solid roller cam with morel lifters.weiand intake,aed 850 db carb.freshened 727 tranny with lba, reverse, manual valve body,10"t/a converter reworked by ptc.67 b-body 8 3/4 rear with 3.91 gears.m/t drag radials 295 55 15.
