Not a full size but a Dodge D50 with a pump gas small block. Drove to track and ran a best of 6.29 @ 109 with a 1.33 60 ft. so far . Just upgraded the fuel system from a mechanical fuel pump to a Magnafuel electric with bigger lines and hope to run faster in the spring. All motor.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
