Why do you "need" to change your distributor?
Whatever. You could do far worse than buying the Firecore stuff, the guy's a board member and seems to be straight up. The distributor is supposed to be really easy to set up.
R.
I would disagree with the Unilite, it's too easy to lose the lite and a replacement one is quite expensive.
