I'm no expert on these but that is one weird looking radio.
I have not seen them all, but I thought an AM/FM with that slider was not available until after 71 and I was under the impression there was no 8 track after 70, so what is that radio correct for
Mike, if you can see the paper tag on the radio that carries the part number and date code it may answer your question as to its' application.
