Quote: Thanks for all the replies. Pulled motor, took it back apart, found the problem. Crank and rods at the machine shop now. I'll assume the blame and pay for repairs, just double checking what critical areas I should look at. I think I'll be fine, parts will be done in 2 weeks.
The mains and rod bearings gone was not the problem, that's the result of the problem . Did you find a problem ? if you didn't, you still have a problem . Don't mind asking questions , there's more talent and experience here then at Chrysler Engineering Facility .
