Probably...most raw forging are minimally machined until final application.
Possibly someone will want to use a six pack rod, thick wall pin and heavy slug....then you need all of that counter.
Large counters are not HP productive......look at one where a light bob was used....it will have the piss drilled out of it...also not a speed tip -
