Contact Ohio and explain. It will be necessary to send it back and have the crankshaft counterweights machined to the proper diameter. If your bob-weight will allow, have the counterweights machined down to the minor diameter.
Did you buy the full rotating assembly from them, if not, do you have the balance sheet?
