Heh, yeah I was not expecting the mileage of a Prius when I bought it. But, I will not go back to a 1/2 ton after having a 3/4, pulling as much as I do. Oh, it is a 4 door also.
The Mikey Thompson's are getting down there in the tread department, but they got grip. Although, gravel roads and heavy loads don't mix well with them. Probably need a new set this fall. What do you guys run that hold up well to heavy loads? I don't care about ride quality.
Not a daily driver but, it is truck and is used like one. More than most of the other clowns with a 7" pipe blowing black smoke out of it....
